c4rmi3r-c0r3
Graphique avec plusieurs facteurs et plusieurs réponses
Bonjour à tous,
Je suis étudiant en chimie, cependant j'aimerai creer un plan d'expérience qui me donne les meilleurs valeurs de facteurs.
Cependant j'arrive a tracer les graphiques en 3D selon 2 facteurs et 1 reponse mais j'aimerai avoir clairement le point ou j'aurai les meilleures reponses.
Merci de votre aide, j'espère avoir été assez claire.
Débit (F)                                Concentration (F)                     Volume reactif (F)          Temperature (F)         Volume injection (F) le reste sont les reponses
10,02510376
12,520376
0,72,520406
10,02520402
0,70,02510406
12,510402
12,520376
0,72,510372
10,02520402
0,70,02510406
0,70,02520372
0,72,510372
7 REPLIES 7
Re: Graphique avec plusieurs facteurs et plusieurs réponses
Bonjour,
My French is very rusty so I used an online translator to better understand your question.  I hope your English is better than my French!
You state you are using 2 factors and 1 response in your 3D graph to see where you have the best outcome for your experimental design.  I would suggest that you use the Analyze > Fit Model > Standard Least Squares platform and then use the Prediction Profiler to determine your best outcome.  The one thing your 3D graph will not be able to show is any interactions.
If you are certain that your 3D graph is showing the best outcome based on the two factors of choice you can use a data filter to select the points of interest as shown below.
Hope this helps.
Meilleures salutations,
Bill
c4rmi3r-c0r3
Thancks for you fast answer.
I want the better point with value factor.
I want a surface with all factors and all response surface to obtain the better yield.
My english is very mad. I try to write to understand me.
Sincerely.
c4rmi3r-c0r3
Ted
Ted
<Analyze > Fit Model > Standard Least Squares > Prediction Profiler>
I did not find "Prediction Profiler" (JMP 10)
Nate_Riordan
Staff (Retired)
As per Bills Instructions and using the coffee data sample:
  1. Fit Model with specification of Standard Least Squares (hit run to get the Fit Model Report):    11454_Screen Shot 2016-05-02 at 8.47.38 PM.png
  2. Prediction Profiler resides within the Fit Model Report:11455_Screen Shot 2016-05-02 at 9.23.48 PM.png
Ted
Ted
Dear nateriordan, Thank you for your attention!
In a JMP 10 this is so:  Fit Model > Standard Least Squares > Factor Profiling > Profiler
Ted
Ted
Bill, Thank you for pay attention to the possibility of building so beautiful 3D graph
