helmon
Graph builder - script speculations and labeling
Hi!
1)
I have data with one column that has two different names (depending on which data I am using).
It is either called "Storage condition" or "Temperature".
I made a graph with graph builder and saved the script, but I would like to use the same script for every database I am using.
I tried to add | to the script - but it doesn´t seem to work.
Any ideas?
Graph Builder(
	Variables(
		X( :Sample name ),
		Y( :Name( "main peak (%)" ) ),
		Y( :Name( "aggregate (%)" ), Position( 1 ) ),
		Y( :Name( "degradation (%)" ), Position( 1 ) ),
		Group X( :Storage condition | :Temperature, N View Levels( 1 ), First View Level( 3 ) ),
		Group Y( :Time point, N View Levels( 1 ), First View Level( 4 ) )
	Elements(
		Bar(
			X,
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Legend( 14 ),
			Bar Style( "Stacked" ),
			Label( "Label by Value" )
		Dispatch(
			"main peak (%)",
			ScaleBox,
			{Min( 90 ), Max( 101 ), Inc( 1 ), Minor Ticks( 1 )}
		Dispatch( {}, "graph title", TextEditBox, {Set Text( "" )} ),
		Dispatch( {}, "X title", TextEditBox, {Set Text( "" )} ),
		Dispatch(
			"Y title",
			TextEditBox,
			{Set Text( "Relative peak area (%)" )}
2)
I have a stacked bar and I added lable by value.
However, when I change the scale (Y-axis), the lower value is not shown (but it is shown when the scale hasn´t been changed).
Can I somehow have the Y-axis scale from 95-100 and yet see both values?
Thanks! :)
Re: Graph builder - script speculations and labeling
My error.....I did not change the column it was getting the conditional check from....try this code
names default to here(1);
dt=current data table();
If(try(dt:Storage condition<<get name)=="Storage condition", theName = "Storage condition",
	theName = "Temperature" );
Graph Builder(
	Variables(
		X( :Sample name ),
		Group X( as column( theName ), N View Levels( 1 ), First View Level( 3 ) ),
	Elements(
		Bar(
			X,
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Legend( 14 ),
		Dispatch(
			"main peak (%)",
			ScaleBox,
		Dispatch(
			"Y title",
			TextEditBox,
7 REPLIES 7
All that needs to be done, is to determine which column has been extracted, and then specify it in the script.  Here is my modification of your script:
If(try(dt:sex<<get name)=="Storage condition", theName = "Storage condition",
Graph Builder(
	Variables(
		X( :Sample name ),
	Elements(
		Bar(
			X,
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Legend( 14 ),
		Dispatch(
			"main peak (%)",
			ScaleBox,
		Dispatch(
			"Y title",
			TextEditBox,
Concerning the stacked bar issue, I suggest you contact JMP Support
     support@jmp.com
helmon
Thank you for this, but it only seems to work when I have "Storage condition" but not "Temperature".
Should I always change the script depending if I have "Storage condition" or "Temperature"? Or can I have in the script "Storage condition" OR "Temperature"?
Thanks!
When you run the script on a data table that has the Temperature column, what error is specified in the JMP Log?
helmon
I´m sorry, I meant the other way around - it works with Temp but not Storage Cond
Graph Builder(
	Variables(
		X( :Sample name ),
	Elements(
		Bar(
			X,
			Y( 1 ),
			Y( 2 ),
			Y( 3 ),
			Legend( 14 ),
		Dispatch(
			"main peak (%)",
			ScaleBox,
		Dispatch(
			"Y title",
			TextEditBox,
helmon
This works! Thank you Jim :)
Now, your new task is to not just run the script, but you need to make sure you understand the script.
