KinshiXian
Graph builder in JMP libraries
Use VB or C # to develop JMP automation, how to reference Graph Buider object, JMP libraries have no Graph Buider object, have similar instance?
ThuongLe
Re: Graph builder in JMP libraries
Could you be more specific?
KinshiXian
We can use the following code in VB program to create a Oneway analysis:
Sub CreateOneWay()
Dim JMPDoc As JMP.Document Set MyJMP = CreateObject("JMP.Application") MyJMP.Visible = True Set JMPDoc = MyJMP.OpenDocument("C:\JMP\SAMPLE DATA\BIG CLASS.JMP")
Dim Oneway As JMP.Oneway
Set Oneway = JMPDoc.CreateOneway
Oneway.LaunchAddY (“Height” )
Oneway.LaunchAddX (“Age”)
Oneway.Quantiles (True)
Oneway.Launch
Oneway.MeansAnovaT (True)
Oneway.MeansStdDev (True)
Oneway.UnequalVariances (True)
Oneway.NormalQuantilePlot (True)
Oneway.SetAlpha (0.05)
Oneway.Save (oscCentered)
Oneway.Save (oscStandardized)
Oneway.CompareMeans occAllPairs, True
Oneway.CompareMeans occEachPair, True
End Sub
So how to use this way create analysis by the Graph builder, such as do Boxplot chart?
I can't find Graph Builder object in JMP library reference.
I Want to use VB to Create Boxplot chart by Graph builder,how can do it?
KinshiXian
Sub CreateOneWay()
Oneway.LaunchOneway.MeansAnovaT (True)
End Sub
KinshiXian
I Can't find graph builder object in JMP Library.
