BookmarkSubscribeRSS Feed
ruiabreu
Community Member
May 15, 2013
Graph builder - creat graphs Spain & Portugal
Good afternoon,
I'm writing to ask if someone as a graph for Spain & Portugal that includes the regions? Or if they a have a procedure or tutorial how to do it.
Regards,
Rui Abreu.
louv
Jun 23, 2011
Re: Graph builder - creat graphs Spain & Portugal
luisgaliano
May 17, 2013
Rui,
I've done that before for Spain, you'll have to figure out to which level you want to delineate (Comunidad Autonoma/ provincia/comarca/municipio..) I've had good success downloading the shapefiles from here: Download | Global Administrative Areas Once you have that downloaded, you can follow the instructions in LouV's post on how to create the zones from the shapefile (basically you need the dbf file which contains all the info for naming and the shp file which contains each of the shapes for each region). Let me know if you need more help once you have the dbf and the shp files on how to create the custom map
LG
