Setsuna
Graph builder auto scale fails when using log scale
When using Graph builder, generally, the axis scale (min, max) is set to reasonable values according to the data range.
But when I set the scale type to 'Log', the scale range will be set to 1E-3 to 1, while my minimum data point down to 1E-12 level.
This makes the curve outside of the graph window, unless I modify the min/max range manually.
But I'm using JSL to process different of data sources. The data structure/range may be so different, it's hard to define a proper range for all the data source.
So is there any method to make jmp auto scale the axis using JSL?
Re: Graph builder auto scale fails when using log scale
How does your script look like? Are you sure that it hasn't been accidentally preconfigured to those values? With JSL you can check from data and estimate what the axis should be.
