Yngeinstn
Graph and Distribution Plots (Where <filter name>)
If you have a graph and/or distribution plots that are associated to different filter states, is there a way to grab that specific filter state and save that to a power point instead of having to save ALL the filter conditions?
I have one column of test data that I need to plot and save with the following test conditions.
Channel = {0, 1, 2, 3, 4, 5, 6, 7, 8, 9}
Test State = {1, 2, 3}
Filter State = {1, 2}
In its current state, that is 60 plots that have to be plotted and saved. I would like to be able to select 1 condition (Channel = 1, Test State = 3, Filter State = 1) and save that plot. I would like to be able to select this from a Filter Condition that i have set up.
In the picture you can see that a single plot for [NF] [CH 8]. As i said before, right now i have to print all iterations:
[NF] [CH 1]
[NF] [CH 2]
[NF] [CH 3]
[NF] [CH 4]
[NF] [CH 5]
[NF] [CH 6]
[NF] [CH 7]
[NF] [CH 8]
[NF] [CH 9]
I hope this makes sense. I am having a hard time communicating this.
Thank You
Re: Graph and Distribution Plots (Where <filter name>)
You are talking about scripted saving? Using the interactive approach I only get the one graph into my ppt plus the filter conditions in additional slides, but not all the different potentially filtered graphs.
