Graph Builder
Is it possible to define a specific size of graph in order to get all the graphs with the same size when copying them into a document ?
hogi
Level XIII
Re: Graph Builder
Re: Graph Builder
You can set the size() of the graph to what you want.  Save the script of the graph to the script window and edit the size to what you want and run the script.
Graph Builder(
	Size( 800, 600 ),
	Show Control Panel( 0 ),
	Variables( X( :Weight ), Y( :Thickness ) ),
	Elements( Points( X, Y, Legend( 3 ) ) )
hogi
Level XIII
Re: Graph Builder
Re: Graph Builder
Thanks, I will try your solution.
