Ted
Ted
Graph Builder
The question is about the Graph Builder (please, see the picture)
Many thanks!
statman
Re: Graph Builder
I'm probably the wrong person to answer, but you can change the scale of the Y axis by double clicking on it (lots of options including Min, Max, Increment, font, reference lines, et. al.).  The greyed boxes are drop zones.  Simply drag a column into the zone.  Depending on the graph you choose (e.g., bubble plot), it will change the size of the plot.
Re: Graph Builder
In JMP 13, you can set the label font by setting the  "Text" font size in the
     File==>Preferences==>Fonts
statman
Re: Graph Builder
Ted
Ted
Re: Graph Builder
Thank you, but these numbers (3, 5 and 7) are not controlled by the axis (it's obvious).
stan_koprowski
Re: Graph Builder
Hi @Ted,
The graph label font size can be adjusted through a preference setting.
  • Go to File-->Preferences
  • Select Fonts
  • Select Graph Labels
Modify Graph LabelsModify Graph Labels
cheers,
Stan
Ted
Ted
Re: Graph Builder
I do not have such in my JMP pro 13.0.0
Re: Graph Builder
