lee_becker
Graph Builder seems to have a limit to the number of pages (100). Is there a setting to change this?
I'm trying to build a report showing multiple assets' performance based on multiple parameters over time in Graph Builder.  I have multiple Y's, a date/time stamp as the X and want to include asset ID as the "page by" var.  Problem is, the result only gives me charts for the first 100 assets.  Is there a setting to change this limit? I can think of several workarounds, but would like to know if there is a simpler solution.
Re: Graph Builder seems to have a limit to the number of pages (100). Is there a setting to change this?
At the current time there is a limit of 100 pages in Graph Builder.  The suggestion that I will make, is to subset your data by the first 100 assets, then the second 100, etc. and then run them seperatly.  You could also easily put the outputs into the same window, side by side, to make it a complete report.
