Juter
Graph Builder: What's the definition of "Error Interval: Range"?
This probably reflects some ignorance on our side, but we couldn't find the definition, neither by using the question mark tool nor by searching the help menus or these forums. The best we can find is here, but it doesn't answer the question.
Here's the menu choice we're referring to.
Byron_JMP
Re: Graph Builder: What's the definition of "Error Interval: Range"?
Check the note at the bottom of the figure.
JMP Systems Engineer, Pharm and BioPharm Sciences
Byron_JMP
Byron_JMP
"Each error bar is constructed using the minimum and maximum of the data"
This note shows up at the bottom of the figure when I make it.
