BookmarkSubscribeRSS Feed
saitcopuroglu
Sep 29, 2014
Graph Builder: Overlaying diengages Color function
Dear Developers,
Is there a way to eliminate the problem of "overlaying disengages the coloring" ?
As seen below, I use color gradient for the bars which makes the data more digestive than just simple default bar colors. However if I use the overlay function of Graph Builder, this extremely usable "color function" does not function anymore. What would you recommend which gives a side to side comparison while retaining the color function?
Many thanks in advance
