charlie95
Graph Builder - Mean vs Sum of Histogram
Hello JMP Community,
Here is my histogram and the statistics. For example, the sum of traffic volume for the first 3 Mondays. The total volume on Monday is roughly 150000.
When I switch the histogram statistic to mean. For example, the average traffic volume for the first 3 Mondays. It's supposed to be roughly 50000 since 150000/3 Mondays, however, it shows a different thing here at about 2000.
Please enlighten me whether I am missing something or I can use additional graph builder function?
Just to provide some background info, it seems JMP divide by 72 instead of 3 as I have 72 separate hours for 3 mondays. Please teach me how to bind them as one?
Thanks,
Charlie
dale_lehman
Re: Graph Builder - Mean vs Sum of Histogram
It is hard to tell without seeing the rest of your dataset, but apparently you have another column that indicates day.  If so, then you can create a new column that shows the number of data rows by day (ColNumber function) and use that to get what you want.  I believe you are correct that since you have 24 hours per day, the graph is showing the average per hour, not the average per day.
Ressel
Try the attached example. It summarizes the height measurements for each age group in a separate column. With this you should be able to bind your Mondays into one number. But summarizing data for each entry of Monday in your dataset may not be what you want, so you may want to create a column identifying each week's Monday, summarize Mondays based on more than one condition (e.g. Monday + week number, or something) or perhaps you already have a column you can use in your table.
