Subscribe Bookmark RSS Feed
Graph Builder - Map Shapes
robbob
Mar 8, 2016
I created a graph using latitude (Y axis) and longitude (X axis).  I used STATE column for Map Shape.  I now see an outline of the united states, but the problem I have is it does not show more than one city in each state.  It will not show a point for Flagstaff and Phoenix....only one dot for Phoenix.  any suggestions to show more than one city in a state?
thanks
ms
Jun 23, 2011
Uncheck X and Y under Points/Variables in the control panel.
In JMP 10 all points would have been shown directly but from JMP 11 the "average" location is shown by default.
Graph Builder(
    Variables(X(:longitude), Y(:latitude), Shape(:state)),
    Elements(Points(Legend(9)), Smoother(X, Y, Legend(8))),
robbob
Mar 8, 2016
I can see all the points now, thank-you.  I have a follow-up question.
Is there a reason why the cities don't match up with the latitude and longitude accurately?  For example, in Florida, the points for Pinellas Park and Key West don't line up well.  They don't match the location on the state or with the x and y axis.  Could the format of latitude and longitude be incorrect?
msharp
Jul 28, 2015
If you notice, by putting the state in the shape box you may or may not have noticed Alaska and Hawaii at the bottom.  JMP is obviously not strictly following latitude and longitude.  If you want the cities to line up correctly instead of just being center of state, right lick >> graph >> Background Map...  Under boundaries select US States.
Graph Builder(
       Variables( X( :longitude ), Y( :latitude ) ),
       Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
              Dispatch(
                                      "Graph Builder",
                     FrameBox,
                     {Background Map( Boundaries( "US States" ) ), Grid Line Order( 2 ),
                     Reference Line Order( 3 )}
ms
Jun 23, 2011
Sorry, I gave you the wrong answer. I meant to write check only X and Y under Points/Variables in the control panel, i.e. uncheck the map shape variable. That should show all points at their right location.
robbob
Mar 8, 2016
This works. Thank-you for your help!
Best regards,
Rob Summers
danschikore
Sep 21, 2012
The Alaska and Hawaii insets have their own axes that are not shown - all mainland points should follow the visible axes.  My graph looks different than yours.  This image is from JMP 11.2.1, and it looks similar in JMP 12.2.  Which version do you have?
Graph Builder(
      Size( 636, 577 ),
      Show Control Panel( 0 ),
      Elements( Points( X, Y, Legend( 1 ), Jitter( 1 ) ) ),
            Dispatch(
                                 "longitude",
                  ScaleBox,
                  {Scale( "Geodesic US" ), Minor Ticks( 0 )}
            Dispatch(
                                 "latitude",
                  ScaleBox,
                  {Scale( "Geodesic US" ), Minor Ticks( 1 )}
            Dispatch(
                                 "Graph Builder",
                  FrameBox,
robbob
Mar 8, 2016
I have version 12.01
Best regards,
Rob Summers
