Graph Builder Export question
I used the graph builder to make a graph with 51 levels (levels in view is set to 1 and there are 51 separate graphs to scroll through).  I am looking for a good way to export them to power point or something so that non jmp users can view all 51 "views" of the graph.  Is there an easy way to do this without copying each page separately?
6 REPLIES 6
jerry_cooper
Staff (Retired)
Re: Graph Builder Export question
If you have JMP version 12, you can drop the column with the 51 levels into the Page landing zone in the lower right corner of Graph Builder. This will create a separate graph for each level. Then select Save As from the File menu and select PowerPointPresentation from the “Save as type:” options in the dropdown menu. This will create a separate PPT page for each level.
Thank you! That worked for me.
Steven_Moore
I like this solution, but I do not get the PPT option from the pull down.  Any suggestions.  Yes, I had PPT open.
Steve
jerry_cooper
Staff (Retired)
You don’t need to have PPT open… what version of JMP are you using? This feature was added in version 12.
Steven_Moore
I am using JMP 12.  I must be missing something!
Steve
Steven_Moore
Peter,
Got it now!  I was clicking "File" from the data table, not the hidden menu bar at the top of the Graph Builder report.
Steve
