BookmarkSubscribeRSS Feed
anne_sa
Community Trekker
Graph Builder - Change the Drawing Order when using a Group Y variable
Hello everybody,
I would like to know how we can uniformize the customization of graphical elements when we use a Grouping column.
Let's take an exemple using the Big Class.jmp table.
I choose "height" as Y variable and "age" as Group Y variable. I display the histogram in addition to the points.
After that, I change the order of elements using the Customize menu so that points are now over histogram.
The modification only impacts the first graph however I would like to have the same think for all the levels of "age" without redoing six times the same action. I tried to copy  paste Cuztomisations but it didn't work.
Any idea of how we could do that ?
Thanks in advance for your help.
Jeff_Perkinson
Re: Graph Builder - Change the Drawing Order when using a Group Y variable
Unfortunately, I don't see any way to affect that for all the groups at the same time.
I'll make a note and we'll see if we can address this in a future release.
-Jeff
Jeff_Perkinson
-Jeff
gzmorgan0
When using GraphBuider (GB), either from the user interface (UI) or using JSL (scripting), order matters.
  • Open Big Class.jmp
  • Start GraphBuilder
  • Drag height to the Y axis and age to the Group X area
  • Right click on any frame and select Points > Change To > Histograms
  • Right click again, select Add > Points
Now Points are last specified GB element and are  on top.  If you save the script, note the elements order
Graph Builder(
	Size( 528, 454 ),
	Variables( Y( :height ), Group X( :age ) ),
	Elements( Histogram( Y, Legend( 4 ) ), Points( Y, Legend( 5 ) ) )
Changing order for all Frame Box would be a nice future option, but until then, keep the elements order in mind when using GB.
anne_sa
Community Trekker
Thanks both of you for your answer.
Indeed it would be a great feature for a future release! :)
