BookmarkSubscribe
anne_sa
Community Trekker
Graph Builder: Change axis settings for a single individual
Hello everybody,
I am looking for a way to highlight an individual label in the Graph Builder.
Here is an example of the kind of graph I want to create (using Big Class.jmp)
I want to focus on Tim and I would like the label "TIM" to be written in bold, or red, or anything that could help me to quickly identify it. I would like something visible by default on the graph and not having to use the Row editor for example.
Do you have any idea?
Thanks in advance!
Re: Graph Builder: Change axis settings for a single individual
A method that I have used in the past, has been to create a subset data table and then to change the value of "Tim" to something like "****** Tim".  This will make the displayed value stand out, however, it also requires that any JSL be able to understand that "******* Tim" needs to be handled when dealing with the original data.
julian
Hi @anne_sa,
Similar to what @txnelson suggested, in situations like these I've set a Value Label in the column properties for just that row so that I wouldn't need to do any recoding of the data. In your example for instance, you could have **TIM** as the Value Label for TIM and that would let you quickly find that row when using the Name column on one of the axes.
anne_sa
Community Trekker
Thank you @julian and @txnelson for this very interresting trick!
It is indeed a nice way to quickly find an individual.
However when we have a high number of indivuals with long names this solution may be less efficient...
Do you know if ts there any possibility to change the color of the label for example?
