BookmarkSubscribeRSS Feed
Graph Buider Chart Axis Scales
eagle
May 4, 2016
I have a 3 level graph builder chart with 4 columns and I need to have the 3 Y axis on different scales. I have been trying to script this but no luck.
ian_jmp
Jun 23, 2011
Please take a look at this thread.
eagle
May 4, 2016
I think I am missing something. I tried the example in the thread but I do not have the red triangle option that you listed "Link Page Areas". Also one viewer stated the page option is in the lower right corner of Graph Builder but I do not have that. I am using jmp 11 so maybe I do not have that access?  Really need to configure the scales separately. Thanks
Jun 22, 2012
Having a page option is a JMP 12 feature.
I believe the point that you are missing from the referenced track is that the final view does not use a Y Grouping as your chart does.  It specifies to split your data into multiple columns, based upon your SDP/SDPC/SDPM and then to include them as separate variables into the graph builder.  When that is done, it allows the axes to be independently set.
eagle
May 4, 2016
Thanks Jim,
I saw that part in the discussion I was just wondering if I am missing something with my version of JMP. Not sure even if I had 12 that I could use the page option? So my follow up for splitting columns is can you do this with scripting or is this only done in the data?
Thanks Again!
Jun 22, 2012
Tables==>Split
That will allow you to split your data based upon your SDP/SDPC/SDPM.  It can also be done in a script too.
