RB
RB
Grab a column switcher box value
Hello friends,
Is there any way to grab the value of user selection in column switcher box?
Column switcher box code is highlited in JSL below. I have also added an image to this message in order to visualize the problem.
M2V1_dt << Bivariate(
     Y( :VALUE ),
     X( :Time_1 ),
     Fit Where(
           :SITE == "A",
           Fit Spline( 0.1, Standardized, {Line Color( {213, 72, 87} )} )
     Fit Where(
           :SITE == "B",
           Fit Spline( 0.1, Standardized, {Line Color( {64, 111, 223} )} )
     Column Switcher( VALUE, {VALUE, VAL2} ),
     Column Switcher( Time_1, {Time_1, Time_2} ),
           Dispatch(
                "2",
                ScaleBox,
                {Add Ref Line( 18, Dashed, "Dark Blue", "+0.5S", 2 ),
                Add Ref Line( 9, Dashed, "Dark Blue", "-0.5S", 2 )}
           Dispatch(
                "Bivar Plot",
                FrameBox,
                {Frame Size( 533, 205 ), Row Legend(
                      SITE,
                      Color( 1 ),
                      Color Theme( "JMP Default" ),
                      Marker( 1 ),
                      Marker Theme( "Standard" ),
                      Continuous Scale( 0 ),
                      Reverse Scale( 0 ),
                      Excluded Rows( 0 )
           Dispatch(
                "Smoothing Spline Fit",
                OutlineBox,
                {Close( 1 ), Set Title( "" )}
           Dispatch(
                OutlineBox,
Thanks,
RB.
Re: Grab a column switcher box value
All of the messages that you can query the Column Switcher are documented in the Scripting Index.
     Help==>Scripting Index==>Column Switcher
Below is the example from the Scripting Index illustrating the Get Current message
dt = Open( "$SAMPLE_DATA/Car Poll.jmp" );
obj = dt <<
Contingency( Y( :size ), X( :marital status ) );
ColumnSwitcherObject = obj <<
Column Switcher(
	:marital status,
	{:sex, :country, :marital status}
ColumnSwitcherObject << Set Current( "country" );
ColumnSwitcherObject << Get Current/*country*/ ;
obj = dt <<
Column Switcher(
	:marital status,
