Share your ideas for the JMP Scripting Unsession at Discovery Summit by September 17th. We hope to see you there!
barneyonion
Giving sequential "runs" a value based on minimum to maximum datetime.
Hi Folks,
I have searched for a way to do this but havent found it online yet.
I have several runs that have a unique ID in this case I will use the label CAR1 to uniquely identify a vehicle. This vehicle will have multiple timestamps as shown
Vehicle   Time
CAR1 10:10am
CAR1 12:30pm
CAR1 17:30pm
I want to find a way to be able to label each row sequentially like this using a new column n.
Vehicle   Time    N
CAR1 10:10am  1
CAR1 12:30pm  2
CAR1 17:30pm  3
Is there a quick way of coding this.
I would like JMP to detect the change to the next CAR here so if I then had entries for CAR2 that it has its own counter and starts at 1 for the earlier timestamp.
Vehicle   Time    N
CAR1 10:10am  1
CAR1 12:30pm  2
CAR1 17:30pm  3
CAR2 2:10pm  1
CAR2 18:30pm  2
CAR2 19:30pm  3
Any help much appreciated.
Re: Giving sequential "runs" a value based on minimum to maximum datetime.
This is a commonly asked question on the Discussion Forum.  A search of "Sequence" will find many of them. However, here is a simple formula to use
If( :Vehicle != Lag( :Vehicle ),
	count = 1,
	count
barneyonion
Thanks a lot for your reply @txnelson
, I went through the LAG and DIF functions and am now familiar with what they do. I tried that formula you suggested, its close to what Im looking for but its labelling both the first instance and second instance within a group as 1 and starts the sequence after that. Is there a way to start the sequence at 1 and increment from there on. This would be extremely useful and its something that I will be using almost daily.
A formula returns the last item calculated, and apparently it is not recognizing the value of count when the first item in the If() function is evaluated.  So the fix is to simply force count to be the last item evaluated in the formula:
If( :CAR != Lag( :CAR ),
	count = 1,
	count
count;
barneyonion
That works perfectly, thanks!
ian_jmp
You could also try:
Col Rank( :PDATETIME, :CAR )
which might have some advantages (depending on what one can and can't assume about the initial sort order in the table).
Article Labels
