011717
Get random numbers upon radio button selection
I am trying to produce random numbers upon radio box selection and produce a number of combination according to user input. So far, this is what I only have.
win = New Window( "LOTTO",
	<<Modal,
	Panel Box( "Select one",
		rb = Radio Box(
				{"6/42", "6/45", "6/49", "6/55", "6/58"} ),
			Text Box( "Enter Number of Combinations" ),
			H List Box( Text Box( "" ),
				textbox_value = Number Edit Box(1) ),
		Button Box( "Ok",
					rb_result = rb << get;
					random = textbox_value << get;
Re: Get random numbers upon radio button selection
It is still not clear to me what you want to do but see if this result is close.
win = New Window( "LOTTO", << Modal,
		rb = Radio Box( {"6/42", "6/45", "6/49", "6/55", "6/58"} ),
		H List Box(
			textbox_value = Number Edit Box( 1 )
	H List Box(
		Button Box( "OK",
			rb_result = rb << Get;
			random = textbox_value << Get;
		Button Box( "Cancel" )
If( win["Button"] == -1,
	Throw( "User cancelled" )
dt = New Table( "Lotto" );
For( c = 1, c <= random, c++,
	dt << New Column( "Draw " || Char( c ),
		"Numeric",
		"Continuous",
		Values(
			Choose( rb_result,
				J( 6, 1, Random Integer( 1, 42 ) ),
				J( 6, 1, Random Integer( 1, 45 ) ),
				J( 6, 1, Random Integer( 1, 49 ) ),
				J( 6, 1, Random Integer( 1, 55 ) ),
				J( 6, 1, Random Integer( 1, 58 ) )
I don't play lotteries so I don't know how to interpret choices like "6/42." Does it mean draw 6 numbers with replacement from 1 to 42?
Anyway, your window as almost complete. Also, you need to check if the user wants to continue. Then use the index obtained from the radio box to proceed. The Choose() function is exactly the right one to use in this case.
	<<Modal,
		H List Box(
		H List Box(
			Button Box( "OK",
Choose( rb_result,
	// add arguments here that depend on the choice from the radio box
// don't know what you want to do from here on.
011717
If the user chose 6/42, it will generate 6 random numbers from 1-42 only.
		H List Box(
	H List Box(
		Button Box( "OK",
		"Numeric",
		"Continuous",
		Values(
			Choose( rb_result,
