Jackie_
Get list of DNS data source name
Is there a way to get the list of the DNS data source using JSL?
Re: Get list of DNS data source name
Scripting Index and JMP Help page I did link should get you there
rp = Run Program( Executable("powershell.exe"), Options({"Get-OdbcDsn"}), ReadFunction("text") );
You could use Run Program(), call powershell, use command Get-OdbcDsn and parse from the return
Jackie_
@jthi Thanks Jarmo!
I haven't used Run Program before. Mind sharing a reference code to save the DNS in the lists?
Jackie_
Appreciate it
