BookmarkSubscribeRSS Feed
Get current language preferences
Hi!
I would like to know if there is any command (could not find one in the scripting guide) in JMP 9 the get the current localization preferences.
My situation:
I have got a script which imports data. But some colleges work with german jmp.
The problem is that in German jmp there is no decimal-point but decimal-komma. The result is that the data is not recognized as numerics but as characters.
So i need to write a script to search & replace "." to ",", but only if the user is working with german JMP.
Thanks in advance!
1 REPLY
martindemel
Jul 10, 2014
Re: Get current language preferences
Re: Running English JSL Scripts on a French PC
Here is a similar situation, may you want to check.
