Get access to column property
KinKame
Nov 30, 2015
I was struggling a little to get column property in my table but finally here is how I do:
  1. set up property in column (color gradient, limit .... )
  2. right click on the column title and select "copy column property"
  3. paste into script window
example as below: I was struggling for the color gradient part
Add Column Properties(
Formula( (As Column( Char( kweek ) || "F" ) - As Column( Char( kweek1 ) || "F" )) / As Column( Char( kweek1 ) || "F" ) ),
Set Property( "Color Gradient", {"Green Yellow Red", Range( {-0.35, 0, -0.03} ), "Reverse Scale"} ),
Color Cell by Value
then in the script it will become
column(dt, "name") << Add Column Properties(
Color Cell by Value
hope it will help some of jmp users
