msharp
Get a .gif to actually run?
Does anyone know how to get a .gif to actually run in a jmp window?  From what I can tell this should work:
img = New Image( "$SAMPLE_IMAGES/progress.gif" );
New Window( "new image 1", img );
But JMP displays a static image.  If you use a command like:
image << Set Current Frame(4);
This should update the image, which it does, but very very slowly. I generally have to wait up to a minute+ to see the change.
As a work around I'm displaying the image in a web browser box, but this isn't ideal.
//this doesn't work?
try(New Window( "new image 2", Web Browser Box("$SAMPLE_IMAGES/progress.gif") ));
//using the full image path does?
New Window( "new image 3", Web Browser Box("C:\Program Files\SAS\JMPPRO\12\Samples\Images\progress.gif") );
