DMeakin1
Get Results from Fit Life by X
When sending the message get results to Fit Life by X the function returns a list that can not be parsed. Below is the log results of running the example script. It is not possible to extract any of the data from the returned list. Note the list has only 1 element and it is 9 characters long id the word Lognormal.
//clear log();
Clear Globals();
dt = Open( "$SAMPLE_DATA/Reliability/Devalt.jmp" );
obj = dt << Fit Life by X(
    Y( :Hours ),
    X( :Temp ),
    Distribution( Lognormal ),
    Censor( :Censor ),
    Relationship( Arrhenius Celsius ),
    Freq( :Weight ),
    Nested Model Tests( Regression )
r = obj << Get Results;
If( Is List( r ),
    Show( r );
    Show( N Items( r ) );
    Show( Length( r[1] ) );
obj << close window;
Close( dt, nosave );
r = {Lognormal({β0(-13.4686494027261), β0 Std Error(2.88719528358502), β1(0.627852956861924), β1 Std Error(0.0828387976570147), σ(0.977823306557825), σ Std Error(0.132646840946067), Covariance Matrix(
[ 8.3358966055556 -0.238821313406502 -0.195117141288106,
-0.238821313406502 0.00686226639725982 0.00592730106968758,
-0.195117141288106 0.00592730106968758 0.0175951844129713]), maximum loglikelihood(-321.702778021814), AICc(649.554624366609), BIC(658.723392465329), Converged("Yes")})};
N Items(r) = 1;
Length(r[1]) = 9;
David_Burnham
Re: Get Results from Fit Life by X
It is possible to extract items from the data structure.  For example:
b0 = r["LogNormal"]["β0"];
b0_se =  r["LogNormal"]["β0 Std Error"];
show(b0,b0_se);
b0 = -13.4686494027261;
b0_se = 2.88719528358502;
-Dave
