BookmarkSubscribeRSS Feed
Jkahler
Community Member
Jul 11, 2018
Generate 3D equation?
Is it possible to generate an equation from a 3D graph? I have seen many options for 2D graphs, but not 3. If so, how should I go about accomplishing this?
Thank you.
cwillden
May 1, 2017
Solution
Re: Generate 3D equation?
What kind of 3D graph?  Are you doing a surface profiler? You can fit all kinds of models for 3 dimensions so it's hard to give any kind of definite answer.
-- Cameron Willden
cwillden
May 1, 2017
Solution
-- Cameron Willden
