ghartel
Generalized regression parameterization of nested effects
I'm using nested effects in the Generalized Regression and find that the parametrization seems strange, maybe wrong?  In the parameter estimates I would expect one row for each level of the nesting factor, with just the name of that level in []'s.  Instead it uses the difference between that level and the reference level.  For the last rows then you get an entries with [reference level - reference level].  That doesn't make sense to me.  To illustrate run the attached code and you'll see rows in the parameter estimates table including these:
Term
Estimate
Std Error
Wald ChiSquare
Prob > ChiSquare
Lower 95%
Upper 95%
Region[South-Southwest]:State[South Carolina-Wyoming]
 -3.902821
115.44404
0.0011429
0.9730
 -230.169
222.36334
Region[Southwest-Southwest]:State[New Mexico-Wyoming]
1547.9147
121.83319
161.42203
<.0001*
1309.1261
1786.7034
Region[Southwest-Southwest]:State[Texas-Wyoming]
1854.3527
115.99596
255.56355
<.0001*
1627.0048
2081.7006
the subtraction of the reference category for State is fine by me, that's like how SAS parametrizes (I know that's different than other JMP platforms), but for the Region, it doesn't make sense? How do I interpret that?
thanks
Gunter
dt = Open( "$SAMPLE_DATA/Seasonal Flu.jmp" );
Fit Model(
	Y( :Flu Cases ),
	Effects( :Region, :State[:Region] ),
	Personality( "Generalized Regression" ),
	Generalized Distribution( "Normal" ),
	Run(
		Fit(
			Estimation Method( Standard Least Squares ),
			Validation Method( None ),
			Normal Quantile Plot( 1 ),
			Active Parameter Estimates( 1 )
	SendToReport( Dispatch( {}, "Model Launch", OutlineBox, {Close( 0 )} ) )
