BookmarkSubscribeRSS Feed
bmarti4
Nov 15, 2016
Gauge R&R results differences between JMP 11 vs JMP 13
I recently upgraded to JMP 13 from JMP 11 and I’m getting different results when running the Gauge R&R option under the Variability/Attribute Gauge Chart. With the same data set, I'm getting different % of Tolerance for the Gauge R&R Measurement Variation values. I overlayed the variability plots and they are identical, just the measurement variation values are vastly different. I need to explain the difference to my customers and need to understand if there was a bug fix or a difference in how the Gauge R&R analyzes the data. Thanks
MikeD_Anderson
Nov 21, 2014
Re: Gauge R&R results differences between JMP 11 vs JMP 13
Since it sounds like there is a time-critical aspect to this question, you might want to send it over to Technical Support (support@jmp.com).
Best,
M
bmarti4
Nov 15, 2016
Thank you! That's my next step.
