pon31
GRR analysis take several seconds . . .why?
       I am trying to run GRR; but when GRR is performed , a window message appear saying "Estimating model parameters" and take several seconds to finish analysis.
       Is there a way to expedite this analysis?
pon31
Re: GRR analysis take several seconds . . .why?
      I found on analysis settings that Bayesian analysis took , alot, more time than use REML method.
      For my purpose looks like difference between both methods is not significant.
      Thanks for help!!
Regards . . .
LP
P_Bartell
There can be many reasons why executing a JMP analysis platform takes longer than one might like. Perhaps you can share your data table and script command string of platform specifications and we can see if we can help with your response time issue? It would also be helpful if you can inform us of the version of JMP you are running and some of the hardware configuration you are running such as Windows/Mac, OS, RAM on the machine, bitness of machine.
pon31
      Thanks for help!!
Regards . . .
LP
