BookmarkSubscribeRSS Feed
valeriel
Community Member
Nov 29, 2013
Formula of std err Prediction
I want to know how to transfer the formula of STD ERR OF Prediction of my linear model in Excel. ( std err Pred Formula)
I dont understand it....what is Vec quadratic ?
Formula is: Sqrt(Vec Quadratic([0.615106074605487 -0.05018339188381, -0.05018339188381 0.00428784520440499], [1] || :T20) * 194.153863605514)
T20 is my variable (temperature at 20 cm under surface)
Thank you very much for your answer!
Jeff_Perkinson
Community Manager
Jun 23, 2011
Re: Formula of std err Prediction
Hi Valerie,
Computing the std err of prediction involves some matrix computations that don't have a direct equivalent in Excel.
In this case Vec Quadratic(S, X) returns the diagonal elements of X * S * Transpose(X).
It appears that Excel could do the matrix multiplication using the MMULT() function and the transposition using the TRANSPOSE() function.
I can't find an Excel function which returns the diagonal elements of a matrix.
-Jeff
-Jeff
