BookmarkSubscribeRSS Feed
Formula bug
vijaysai
Community Member
Mar 27, 2017
Hi I am getting error while I run this code.
Is there any mistake i am overlooking ?
 //Remove brackets in All Column names
dt1 << deselect all();
wait (0.5);
//int i = 0;
For (int j = 7, j <= 86, j ++,
col = Column (j);
colname = "I" || Char(j-6) || "_nA";
col << Set Name(colname);
1 REPLY
Jeff_Perkinson
Community Manager
Jun 23, 2011
It appears that you're trying to declare a variable type before your variable j by prefacing it with int.
There are a couple of issues with this:
  1. JSL doesn't require (or support) declaring a variable type.
  2. Spaces are ignored in JSL, so in your code your loop counter variable is actually "int j". So, when you refer to "j" in the comparison it is undefined.
Just remove the "int" and your code should not produce the error.
-Jeff
