Formula Col Min() Returning Subsequent Value Assistance
patrickw
New Contributor
Sep 25, 2017
I am quite new to JMP. I have a data set similar to the one shown here for 4000 ID's. Each ID has a Count value for several different dates, and I have the set sorted by ID first then by Date.
I am interested in generating a formula that will result a 1 next to the first Count value >=500 that occurs after the 0's within each ID (only when there are 3 consecutive Count values >=500). With this logic, the formula should return a 1 at row 17 and 38 (NOT 35 because there are not 3 consecutive values >=500) in the example provided. I have attempted a stacked If( row()==Col Min(row(), ID)) strategy but have been unsuccessul. Any and all help is greatly appreciated. Thank you.
Jun 22, 2012
Solution
Here is my version of your requested formula
If( Row() == 1,
	zero = 0;
	found = 0;
If( Lag( :ID ) != :ID,
	zero = 0;
	found = 0;
If( :Count == 0, zero = 1 );
If( zero == 1 & :Count >= 500 & :Count[Row() + 1] >= 500 & :Count[Row() + 2] >= 500 & found == 0,
	found = 1;
	1;
And attached is your sample data table with the formula applied
Jun 22, 2012
Solution
If( Row() == 1,
	zero = 0;
	found = 0;
	zero = 0;
	found = 0;
	found = 1;
	1;
patrickw
New Contributor
Sep 25, 2017
Thank you for your prompt response. When I apply the suggested formula it appears to terminate after the first ID and does not repeat for subsequent IDs (i.e., I am only getting a result returned on row 17).
patrickw
New Contributor
Sep 25, 2017
I think maybe the issue is arising because the IDs are not sequential numbers?
Jun 22, 2012
Did you look at the data table I attached.  It had values in row 17 and in row 38.  Have you looked into the log to see if errors are occurring?
The IDs do not have to be sequential.  Take a look at the formula, and from it you should be able to see how it is working.
