oscarmforero
Format column to do not "Keep trailing zeroes"
Hi community
I'm setting the engineering SI format to my colums, but i cannot remove the option to set the "Keep trailing zeroes", it seems that its always set by default, how can I remove it?
column << Format( Engineering SI, 10, 5, "Keep trailing zeroes");
Thanks,
Oscar
gzmorgan0
Re: Format column to do not "Keep trailing zeroes"
@oscarmforero,
The syntax should be
		Format(
			"Engineering SI",
			Keep trailing zeroes( 0 ),
			Keep all whole digits( 1 ),
			10,
			5
A simple way to learn the expected syntax is to make a simple table using the UI, then click on the red inverted triangle, the menu icon, next to the table name. Select Copy Table Script. Open a script window and paste it.  The column format is within the script.
gzmorgan0
@oscarmforero,
		Format(
			"Engineering SI",
			10,
			5
oscarmforero
Thanks for the tip! :)
