BookmarkSubscribeRSS Feed
mawriter
Community Trekker
Forest Plots with JMP 9
I need to know if I can create forest plots when performing meta-analyses with JMP 9.
XanGregg
Try the Relative Risk chart in Categorical, which may suit your needs. I think it has the relevant information in a slightly different form.
dt = Open( "$SAMPLE_DATA/Quality Control/Failure3Freq.jmp" );
obj = Categorical(
          Response Frequencies( :contamination, :corrosion, :doping,
                    :metallization, :miscellaneous, :oxide defect, :silicon defect ),
          Sample Size( :SampleSize ), X( :clean )
obj << Relative Risk( 1, {}, {"after"} );
XanGregg
obj = Categorical(
mawriter
Community Trekker
Thank you!
