bwilliamson
Force inclusion of specific corners in a DoE matrix
Hi all.
I think I may be trying to do the impossible, but I thought I'd ask first. We're trying to run a 5-factor 2-level matrix in 6 runs AND force inclusion of an all low and/or an all high condition while maintaining 6 runs.
The above goal nonwithstanding, is there a way to force inclusion of a set of factor settings into a custom design?
Thanks for any input.
Re: Force inclusion of specific corners in a DoE matrix
If you have JMP 13 or 14, another option would be:
- create the full factorial design for the 5 factors (DOE-> Classical -> Full Factorial)
- with that data table open, select the row(s) you want included
- start Custom Design, use Add Factor->Covariate, and select your 5 factors
- after the continue, right above the run selection, there should be a checkbox for "enforce use of selected covariate rows".
- check this box, and change your run size to 6.
Hope this helps,
Ryan
You could make a table with the runs you want to include and use Augment Design.
Dan Obermiller
bwilliamson
OK that makes sense... But I'm getting a strange error. JMP claims it has experienced an access violation error and then automatically creates a .JER log file of the event. For whatever reason I can't attach that file to this post.
Any ideas on what's going on here?
Thanks for your help..!
That is a question that will need to go the JMP Technical Support team. You can send an email to support@jmp.com or give them a call.
Dan Obermiller
Hope this helps,
Ryan
bwilliamson
That got it.
Thanks!!
