cwillden
Force Open() to Use Excel Wizard Without Changing Preferences
Hey JMP Community,
I'm building an application where a user can import data from Excel or from a JMP table.  I'm getting the file path via Pick File().  If they select an Excel file, I want to coerce JMP to use the Excel Wizard without changing the user's preferences.  In the Scripting Index, I found something called Excel Open Method() which has an option "Use Excel Wizard"; however, there is not an example.  It is a message, but does not specify what type of object is compatible with that message.
Any ideas?
Thanks,
Cameron
-- Cameron Willden
cwillden
Re: Force Open() to Use Excel Wizard Without Changing Preferences
Of course, I immediately found the answer after posting. In Chapter 9 of the Scripting Guide:
"Note: To use the Excel Wizard, you must specify the Excel Wizard option in the argument as in Open( "$SAMPLE_IMPORT_DATA/Team Results.xlsx", "Excel Wizard" );."
Instead of deleting the post, I figured I'd leave the answer here if anyone else ever needs it.
-- Cameron Willden
cwillden
-- Cameron Willden
