BookmarkSubscribeRSS Feed
For subject IDs with more than one value in a column, how do I select for maximum value
bpulinat
Community Member
Jun 23, 2017
1 REPLY
Jun 22, 2012
There are a few different solutions.  The most basic is to create a Summary data table, specifying to find the Maximum value of the measurement column, By subject ID.
     Tables==>Summary
You can also use the Tabulate Platform to create a report where you place the SubjectID as a grouping row or column, and then dragging the measurement variable into the table, specifying to find the Maximum
     Analyze==>Tabulate
A new column could also be created where you would specify a formula for the column, where the formula is
     Col Maximum(measurment column, subjectID)
