BookmarkSubscribeRSS Feed
datadisk
Nov 7, 2013
For Loop does not evaluate formula correctly.
I am trying to create new columns in a data table, each new column is the Z-score of an existing column.  Here is what I have
Colnames_1st = dt_zscore3 << Get Column Names();
nlist = N Items(Colnames_1st);
for (i=5, i <=10, i++,
    var1 = Column(Colnames_1st);
    mean = Col Mean(var1);
    stdev = Col Std Dev(var1);
    namevar = char(Colnames_1st);
    New Column("Zscore " || namevar,
    Numeric, Continuous,
    Format("Best", 12),
    Formula((((var1[]) - mean )/stdev )));
The code creates the 6 new columns and names them correctly.
But when it goes to fill in the values in all the columns, it does not do it correctly.
All the columns end up with the same value in each row.  It looks to me like it
is creating the columns, but then waits til the for loop is over to calculate the
values that go in each row in all the columns, so it uses the last value of all
the variables for all the columns, instead of calculating the formula for each
column using the values that should be used by that column.
I am really stuck.  I have tried all sorts of things but can't get over this hurdle.
Any help would be much appreciated.
datadisk
Nov 7, 2013
Re: For Loop does not evaluate formula correctly.
I think I finally found a solution.
I have a feeling that my problem lies somehow in defining variables as local vs global, but no matter what I tried I could not figure out how to fix it that way.
Instead I added the line
    dt_zscore3 << Run Formulas
and now it does it correctly.
for (i=5, i <=nlist, i++,
    //var1 = Column(Colnames_1st);
    Format("Best", 12),
This is possibly not elegant or the most correct way to do it, but I post it in case anyone finds it useful.
ms
Jun 23, 2011
I think there may be a problem with your solution. It may work when the columns are created, but not in another session or if data is changed or added in the source columns.
If you look at the formulas in the new columns I suspect the will all look like "(var1[] - mean) / stdev". These variable names only make sense in the current script context (or even within a specific for-loop iteration. If the variables are redefined or cleared the formulas will not work properly.
Formulas should be entered literally because the variables in the Formula() argument are apparently not evaluated but taken literally. If variables have to be used, e.g. in for loop, this can be achieved by manipulating strings or expressions.
Example using evalexpr() to evaluate expresions within an expressions before evaluating it:
n = N Col( dt );
For( i = 4, i <= n, i++,
  var1 = Column( i );
  Eval(
  Eval Expr(
  dt << New Column( "Zscore " || (var1 << get name),
  Numeric,
  Continuous,
  Formula( Col Standardize( Expr( var1 ) ) )
