Jim101
Font type and size in analysis summaries. How do you change them when pasting into Word? They are too small. am using the metafile special paste.
Re: Font type and size in analysis summaries. How do you change them when pasting into Word? They are too small. am using the metafile special paste.
3 Options here - the first is to tinker with the fonts in your preferences (in JMP) to increase the font sizes relative to the graphic. The second is to actually make the graph smaller than you think it should be (I run into this problem when moving graphics between apps optimized for my macs Retina display and ones that aren't). The third option is to right click on the graphic and select "Group > Ungroup." From there you can tinker with the fonts directly in the application
best,
M
Jim101
Thank you, will do soonest.
