Tzu-Chun
Fix the graph size of analysis result by using JMP scripting
Hi
I was trying to fix the size of frame box in the analysis result, the following code as an example:
dt = Open( "$SAMPLE_DATA/Flight Distances.jmp" );
dt << Multidimensional Scaling( Y( :Birmingham, :Boston, :Buffalo, :Chicago, :Cleveland, :Dallas, :Denver, :Detroit, :El Paso, :Houston, :Indianapolis, :Kansas City, :Los Angeles, :Louisville, :Memphis, :Miami, :Minneapolis, :New Orleans, :New York, :Omaha, :Philadelphia, :Phoenix, :Pittsburgh, :St. Louis, :Salt Lake City, :San Francisco, :Seattle, :Washington DC ), SendToReport( Dispatch( {"Multidimensional Scaling Plot"}, "MDS Report Plot", FrameBox, {Frame Size( 750, 500 )} ) ) );
The frame size (750, 500) is the desired setting. However, it became to the default setting after I click the "Flip Vertical" of "Flip Horizontal" button.
                                 before        After
Is there a way to fix the size of frame box autometically using JMP scripting instead of right click the frame box and set the fram size manually?
ih
ih
Re: Fix the graph size of analysis result by using JMP scripting
One way would be to set the frame size and flip the graph using JSL.  The report from 'mds << Show Tree Structure;' shows where 'FrameBox(1)' came from.
mds = dt << Multidimensional Scaling( ... );
mds << Flip Horizontal( 1 );
(mds << Find( FrameBox(1) )) << Frame Size ( 750, 500 );
To make this interactive you could replace the flip buttons with your own:
Names default to here( 1 );
		Dispatch(
			"MDS Report Plot",
			FrameBox,
//Hide the default Flip buttons:
(mds << Find( Button Box(1) ) ) << visibility( "collapse" );
(mds << Find( Button Box(2) ) ) << visibility( "collapse" );
//Add new Flip buttons that set the frame size
(mds << Find( Listbox(3) )) << Append( Button Box(
	"Flip Vertical New" ,
	mds << Flip Vertical( 1 );
	"Flip Horizontal New" ,
ih
ih
		Dispatch(
			"MDS Report Plot",
			FrameBox,
Tzu-Chun
Thanks so much, that was exactly what I need.
