Fitting generalized linear mixed models - missing response distribution options
Hi there,
I am using the Generalized Linear Mixed Model platform in JMP Pro 17.2 to analyze data for my dissertation. My response data is positive and continuous but not normal. I would like to use Gamma for the response distribution, but the only available options are Poisson and Binomial. Gamma (+others) are available under the Generalized Regression platform, but one of my effects is random so I need to use a mixed model. JMP's help page for the GLMM platform says that other distributions are available for continuous response data, but I do not see them. Is there a way to fit a GLMM with distributions other than Poisson/Binomial in this case? Thanks!
MathStatChem
Re: Fitting generalized linear mixed models - missing response distribution options
