gh
gh
Fit Linear submit to SAS via Script
The modal dialog of the Fit Model Platform allows the model to be submitted to SAS via a dialog option. Does anyone know how to use that feature via JSL?
thanks
Gunter
mattf
Level V
Hi:
in JMP 9.02, From the Help Menu, Object Scripting, Fit Model, Model Dialog example:
dt = Open ( "$English_Sample_Data/Tiretread.jmp")
obj = Fit Model(
     Y(:ABRASION),
     Effects(:SILICA< SILANE),
     Personality(Standard Least Squares)
obj << Submit to SAS;
obj << Run Model;
Best regards,
-Matt
mattf
Level V
Hi:
obj = Fit Model(
     Y(:ABRASION),
obj << Run Model;
Best regards,
-Matt
gh
gh
Thanks Matt,
I forget about that part of the help system.  Quite handy.
Cheers
Gunter
mattf
Level V
Also handy - what messages does the object know?
obj = Fit Model(.....
Show Properties( obj );
& check the log for a list of available messages, including more commands than one can do by scripting alone.
Best,
-Matt
