thana
Fit Group save picture unsuccessful.
Hi
I'm normally use
Report( name ) << save picture( "path/filename.png", "png" );
and it's working fine.
but this time with large set of Fit Group it's not working as normal.
Is the report size or something effected the save picture function ?
Script is not error since it can be run and the output file is generated but with 0 byte and have no data.
any suggestions ?
Re: Fit Group save picture unsuccessful.
I can imagine that saving a single .png image might have a size limitation. How many objects do you have within your Fit Group?
thana
in this case 138 obj of bivariate plot
