garyb
First and Last SAS Functionality in JMP
Does JMP have first and last functionality similar to that in SAS?
e.g.
if first.variablename then
if last.variablename then
XanGregg
Re: First and Last SAS Functionality in JMP
I'm not familiar with the constructs, but from a quick search I gather you want to if the current row contains the first or last occurrence of a particular variable's value in a data set sorted by that variable. I think that would be:
if (:var != Lag(:var), ...); // first
if (:var != Lag(:var, -1), ...); // last
tom
tom
Wouldn't the equivalent in a matrix language just be indexing to the first value or the last value?
