BookmarkSubscribeRSS Feed
garyb
Community Member
Sep 6, 2012
First and Last SAS Functionality in JMP
Does JMP have first and last functionality similar to that in SAS?
e.g.
if first.variablename then
if last.variablename then
XanGregg
Jun 23, 2011
Re: First and Last SAS Functionality in JMP
I'm not familiar with the constructs, but from a quick search I gather you want to if the current row contains the first or last occurrence of a particular variable's value in a data set sorted by that variable. I think that would be:
if (:var != Lag(:var), ...); // first
if (:var != Lag(:var, -1), ...); // last
tom
Community Trekker
Jul 9, 2011
Wouldn't the equivalent in a matrix language just be indexing to the first value or the last value?
