daniel_harding
Finding the area beneath the curve
  I am trying to find the area beneath a curve of a given data set. In a previous posting I found some jsl script that helps get the area after using analyze>modeling>non-linear and then using a Gompertz function to get the equation. The problem is the code crashes when I try to run it after I have found that equation. Below is the code and thanks for any help or suggestions
Clear Globals();
xmin=0;
xmax=120;
stop=0.000000001;
pdf=function( {x} , 1.16929740059737 * Exp( -Exp( 0.46956698638041 - 0.00339164235623826 * x ) ) );
//it appears that {x} is what crashes the program, but without it, that line of code has errors
intervals=1;
last=0;
new=0;
flag=0;
while(flag==0,
intervals=intervals+1;
increment=(xmax-xmin)/intervals;
total=0;
for(i=1, i<=intervals, i++,
  if(i==1, x=xmin);
  if(i>1, x=x+increment);
  total=total + ((pdf(x))/2)*increment;
last=new;
new=total;
diff=abs(last-new);
if(diff<=stop, flag=1);
show(intervals);
show(total);
pmroz
Re: Finding the area beneath the curve
Your value of stop is pretty small.  You might consider raising it a bit, but that really depends on how many significant digits you want to converge on.  Also use {default local} in your function so as not to confuse JMP about x.  Here's my modification:
Clear Globals();
xmin = 0;
xmax = 120;
stop = 0.000000001;
pdf = Function( {x}, {default local},
intervals = 1;
last = 0;
new = 0;
flag = 0;
While( flag == 0,
    intervals = intervals + 1;
    increment = (xmax - xmin) / intervals;
    total = 0;
    For( i = 1, i <= intervals, i++,
        If( i == 1, x = xmin );
        If( i > 1, x = x + increment );
        total = total + ((pdf( x )) / 2) * increment;
    last = new;
    new = total;
    diff = Abs( last - new );
    If( diff <= stop, flag = 1 );
    //print(intervals);
    if (mod(intervals, 1000) == 0,
        print(char(intervals) || ": " || char(diff) || " Total: " || char(total));
Show( intervals );
Show( total );
Results are shown here.  I hit the ESC key to stop execution.
"1000: 0.0000050154411717074 Total: 19.0754942945052"
"2000: 0.0000012532594197978 Total: 19.0779995336205"
"3000: 0.0000005569154488683 Total: 19.0788346249656"
"4000: 0.0000003132397878858 Total: 19.0792521728205"
"5000: 0.0000002004643206988 Total: 19.0795027022319"
"6000: 0.0000001392066906192 Total: 19.0796697221303"
"7000: 0.0000001022719047228 Total: 19.0797890222006"
"8000: 0.0000000783009035388 Total: 19.0798784973311"
"9000: 0.0000000618661744056 Total: 19.0799480891457"
"10000: 0.0000000501117192186 Total: 19.0800037626261"
"11000: 0.0000000414136884785 Total: 19.0800493136749"
