BookmarkSubscribeRSS Feed
adam
Sep 20, 2017
Find and Label Column
I have 2 columns, ID1 #  and ID2# as shown below and both are not in orderly manner. I would like to know how can I use ID1# which is recorded as F(in FAIL1 column) and find the same number in ID2# and then label as F in FAIL2 column as shown in example below.
Thank you.
ID1FAIL1ID2FAIL2
AB11A972C99NFABV1A9781NN3
AB11AB7DDS8NFABK1AB7E8186
AB11AB7J9945FABD1E974C2FM
AB11AB7K2PLRFABN1E275SV4E
AB11AC70J01HFABD1E977ZMSL
AB11AC70J10VFABJ1AB750FYP
AB11AC70J120FABP1E270SWJH
AB11AC70J1C1FABU1E36194WM
AB11AC70J1ZRFABW1AC62A4RY
AB11AC70J22CFAB91EB6DCMFM
AB11AC70J33TFABD1A667K0FR
AB11AC70J394FABM1A67KKNUK
AB11AC70J4Z5FAB81A37PN5SH
AB11AC70J5ULFAB81E87AYYUC
AB11AC70J681FABW1AC62A93N
AB11AC70J7CSFAB21A47N49XU
AB11AC70J8Z4FABP1EB6D12XK
AB11AC70J9R2FAB11AC70J22CF
AB11AC70JA3DFAB21AC77P9HA
AB11AC70JC6AFABJ1AB79ULEV
AB11AC70JCN6FABU1E879EMAV
AB11AC70JDDHFABD1A667K70L
AB11AC70JDFJFABH1AB71A2UX
AB11AC70JEPYFAB11AC70J9R2F
Jun 22, 2012
Solution
Re: Find and Label Column
Assuming that your ID columns actually have a "#" in the name, the following script will do the trick
dt = Current Data Table();
For( i = 1, i <= N Rows( dt ), i++,
	FoundRows = dt << get rows where( :Name( "ID2#" ) == :Name( "ID1#" )[i] );
	If( N Rows( FoundRows ) > 0,
		:Fail2[FoundRows] = "F"
Jun 22, 2012
Solution
Here is another methodology
dt2 = dt << subset( Invisible, selected rows( 0 ), columns( :Name( "ID1#" ), :Fail1 ) );
dt2:Fail1 << set name( "FAIL2" );
dt = dt << Update(
	with( dt2 ),
	Update,
	By Matching Columns( :Name( "ID2#" ) = :Name( "ID1#" ) ),
	Drop multiples( 0, 0 ),
	Include Nonmatches( 1, 0 ),
	Preserve main table order( 1 )
Jun 22, 2012
Solution
adam
Sep 20, 2017
Hi Jim,
Thanks a lot..!
It's working as expected.
adam
Sep 20, 2017
Hi Jim,
I have one more question. In my real case my ID2# has about 70K rows but the ID1# has only about 3K rows. When I ran the script, it's like taking more than 30minutes to complete  :-)  Is there any faster way to shorten the duration.
Thanks.
Jun 22, 2012
Solution
dt = dt << Update(
	with( dt2 ),
	Update,
