Find Hidden or Displayed FrameBoxes
robot
Feb 27, 2012
Ian@JMP​ shared a JSL function (below; originally written by Joseph Morgan) that will return a list of each FrameBox, whether it is displayed or not.  The function works great, but I would like to be able to access only FrameBoxes that are displayed.  What is the best way for JSL to determine if a FrameBox is displayed or not?  I am using JMP12.
Thanks!
NamesDefaultToHere(1);
ClearLog();
// This function recursively traverses a display tree producing
// a pre-order listing of the names of display boxes that constitute
// the tree. It also looks for each FrameBox (whether displayed or not),
// and gets the name of the parent OutlineBox
preorder = Function({node},
   Local({chnode},
    // Inspect the current node
    nodeType = Char(node << className);
      Print("Node: "||nodeType);
      If(nodeType =="FrameBox",
  // Find the title of the parent outline node of this FrameBox
  parent = node << parent;
  parentType = Char(parent << className);
  While(parentType != "OutlineBox",
  parent = parent << parent;
  InsertInto(fbTitles, parent << getTitle)
    // Do the recusrsion
      chnode = node << child;
      While(IsScriptable(chnode),
         Recurse(chnode);
         chnode = chnode << sib;
// Try out 'preorder' . . .
obj = dt << Fit Model(
  Y( :height ),
  Effects( :sex ),
  Emphasis( "Effect Leverage" ),
  Run(
  :height << {Lack of Fit( 0 ), Plot Actual by Predicted( 1 ),
  Plot Regression( 0 ), Plot Residual by Predicted( 1 ),
  Plot Effect Leverage( 1 )}
report=report(obj);
fbTitles = {};
preorder(report);
Print("\!n", fbTitles);
robot
Feb 27, 2012
Solution
This question is answered.  Please see discussion at:
Find All Display Tree Elements
1 REPLY
robot
Feb 27, 2012
Solution
