pmroz
Find (CTRL-F) in JSL script editor doesn't use entered case of text
Wondering if anyone else finds this behavior annoying?  If I have a past search in JSL code for "country", and then at a later time I want to search for COLD (note uppercase), what gets entered is cOLD.  The find window remembers past searches and tries to be smart about it, but I want it to use the case I type in.  This happens in JMP 14, 15 and 16.
Thierry_S
Re: Find (CTRL-F) in JSL script editor doesn't use entered case of text
I have the same issue with JMP 14.1: the only workaround I have found is to select the "Match Case" option which is annoying indeed.
Best,
TS
Thierry R. Sornasse
This sounds like a bug and you should pass it to
     support@jmp.com
