dayvie
Filter by a differnce between two dates
I have a data set with a column of dates.  I am trying to filter the rows based on the difference between the existing date column and today.  I can subtract the date from today() and use the data filter on the table, but when I try to use the script it never selects any rows.
This is the data filter script that I was using:
Current Data Table() << Data Filter(
Location( {2166, 239} ),
Add Filter(
  columns( :Days to Last Modified ),
  Where(
   :Days to Last Modified >= :3:06:40:08 & :Days to Last Modified <=
   :4:00:00:00
  Display( :Days to Last Modified, Size( 73, 16 ) )
works fine using the data filter, but not when I run it from a script...
